99% load on hard drive
pavel007113
6
My hard drive has 99 % load all the time so i get studering in games . I bought new one and it was the same then i reinstall windows and driver but still the same.
Ah....OK....I understand.
Try and going to "resource monitor". There you will find your disk usage and a sortable column.
Sort the column so the app that is using the disk the most is at the top.
That should show you what software is constantly using your drive.
You go in windows and open task manager and you see load of cpu,ram... and my hard drive is on 99% load(usage)always.I had a wd 1tb hard drive that had the same problem than i bought new hybrid hard drive from segate.Than i reinstall widows and game fortnite but i was still geting stuttering in game
