$99 SenseHUD Merely Beginning Of SenseDriver's Push For Auto Display Platform Dominance
How would you avoid the 30 minute limit requirement before having to key in your password/patern on your phone again?
Many apps feature an override for your phone's auto-lock (hopefully this one will). Or perhaps your phone allows you to leave the screen on indefinitely when plugged into a power source? Or you could disable the auto-lock behavior on your phone altogether...
There are a few apps that work on variables (Automatic Device, IFFT...) that can adjust settings for you. Would be easy to add something like "if SenseHub is active, then turn off "automatic lock" type of deal.
What's the difference between having this and having a traditional car mount? You're still looking at your phone's display, and you can also give it voice commands while you drive. IMO, it'll be a flop.
