Question 9900k cooling help
techylavi
6
I am working on fixing an overheating computer with a broken AIO. The system is running an i9 9900k at stock settings. The user games heavily and needs a new cooler to replace the broken AIO. An air cooler is preferred. What would be the best air cooler to cool a 9900k? I was looking at the be quiet dark rock pro 4 but the computer has all dimm slots occupied with Ripjaws 5). Could someone tell me a good air cooler that would work to cool his 9900k while also fitting over the ram?
Lutfij
Make and model of your motherboard? Make and model of your case being used? If clearance isn't an issue, you might want to look into the Be Quiet! Dark Rock 4 cooler. That also leads me to the other questions, what is your budget for the cooler, where are you/the owner of the system located and what is your preferred site for purchase?
