9900k temps with custom loop 2x 360 rads
kba1980
17
Jesus this thing is hot even with my custom loop and 2 360 rads. 5.1ghz at 1.350v and llc set to 7 which makes it go to 1.362 volts under load I am getting 94 degrees max core temp in prime 95 version 26.6 small fft.
Does this sound right anyone else running this heater. I am going to put another radiator in it when it gets here and check thermal paste application but I have been doing this a good while so I don’t see that being a issue unless I just got a bad mount. Thermal paste is kryonaut.
Thanks!
kba1980
17
Pump is set to max it’s a d5. Water flow is meh it’s ok I got something rigged up at the moment until my other rad gets here so flow is definitely being hurt some but it isn’t affecting the gpu temps. I doubt flow is hurting no more then a degree or 2 at most. Fans are Corsair ml static fans 9 of them and are running wide open 2400rpm
kba1980
17
Yea I seen this thread I have been trying to see if this is normal. I knew going in that it was hot but most test are done with a AIO setup and honestly they seem to be performing really close to my custom loop.
I have it set to 1.320 in bios now and it’s at 1.331 in stressing test. I am running p95 26.6 at the moment and running custom and ffts in place at 1344 and it’s peaked at 86c seems to be running constantly high 70s low 80s on all cores. It’s 38min in.
