A better case for overheating computer
Absolent
27
Hello, what would be the best case when it comes to cooling since my PC suffers of slight overheating (performance drop, no bluescreen or anything severe) which irritates quite a lot.
I've literally put a desktop fan next to it to keep it cool which it does though doesn't 100% effectively counter the problem.
So if you could give me, say, 3 different cases with the reason you recommend them, the cheaper the better. If you wish to know the budget, make it under 80€, but just still as cheap as possible. Thank you!
Could be. The computer is an ASUS Essentio CM6730, which I nailed for a good deal to get it. It appears from my research that some have had overheating problems and so, I did add as much fans as I happened to have and only one slot was left open. I think I could try to add thermals if it could help enough. The computer's case seems pretty sealed though.
EDIT: by sealed I ment sealed from airflow, but not from opening up.
Yes I understand what you mean by "sealed". Sealed does a better job of air flow and cooling as compared to a computer with the side cover open. In fact, some computers have an interlock switch that prevents operation when the cover is taken off.
You should look at a better heatsink, and re-installing the CPU/heatsink before you consider a new computer case.
