Hello, even after keeping the room tightly sealed etc and taking all other precautions, eventually some fine dust seems to be accumulating inside the cabinet and PSU..
Right now I cleaned inside of cabinet and motherboard and gfx card with a very soft thick painting brush and removed whatever little dust i could collect .. but I could not clean properly inside PSU. I really dont want to disconnect stuff just for dust cleaning.. I bet some product is available which has a bit of suction to it and is specifically designed for PC cleaning? .. to clean the fan blades near the motor part etc ..
I know that I should not use a blower or such to just blow away the dust, dont want to damage anything ..
Is there any good product to clear the cabinet and psu from dust?
thanks
thanks
