A build enough for minecraft?
Yes its great since minecraft is a cpu based game because it runs through java, if you want to get beast fps even with shaders and very high resolution resource packs you can add in a very cheap graphics card, if you search "best budget gpu - austin evans" you will get great cheap options, but the graphics that comes with the cpu will be more than enough! :)
(Remember to pick best solution)
You dont really need the AMD intergated GFX. Minecraft runs poorly on AMD APU's from my experience. If you get an Intel i3 or i5 with at least HD 4000 graphics you should run the game better. The only difference is the price which i think will be the same.
