A build I found.
boboyboxer
23
Hi, so I want to run BF4 and Dayz and whatnot so I need a new pc and this one looks good http://pcpartpicker.com/p/2uLaE
Im not sure if it will work the best all I know is gpu is good but the cpu Im worried about and I need to know if it can run games well with no lag from it. Im going to sleep now and I will see it tomorrow night so I will tell you about my goals I want bf4 dayz and planetside to run I need it around 450 dollars a bit of stretching can be done to like 500 but I dont really want to.
the build is fine and will run those games but I will warn you now that it won't run very well, BF4 is a very demanding game, a 7750 will get you barely playable frames on medium/high settings at a lower resolution like 1680 x 1050 or 1600 x 900. If you lower the resolution or settings further you can get smooth frames so if you don't mind that then you'll run these games with no trouble.
the processor is fine and fits the rest of the build well.
