A classic problem 3 monitors on 270x
Johnabie
I have two ELEFT407 40" 1080p screens and one NS-39L700a12. Windows gives me "unable to save display settings" when I try to enable any third monitor. I'm only able to display thru any 2 at a time.
I have tried to connect the screen in multiple fashions IE
Displayport thru active adapter to hdmi x dvi to hdmi x hdmi
Displayport thru active adapter to hdmi x dvi to hdmi x dvi to hdmi
Displayport thru active adapter to hdmi x dvi to vga x dvi to hdmi
Displayport thru active adapter to hdmi x dvi to vga x hdmi
Displayport to hdmi x dvi to hdmi x hdmi
Displayport to hdmi x dvi to hdmi x dvi to hdmi
Displayport to hdmi x dvi to vga x dvi to hdmi
Displayport to hdmi x dvi to vga x hdmi
dvi to hdmi x dvi to hdmi x hdmi
I have also tried the setup with 3 dell 19" 4:3 with no luck.
I have also tried every setup first screen than duplicated then extend.
I have also tried using 800x600 as that sometimes helps.
I have also lowered from 32bit colour to 16bit.
I have also downloaded software to force triple monitor like "actual multiple monitor" and others.
Display port adapter used
http://www.club-3d.com/index.php/products/reader.en/product/displayport-to-active-hdmi-3d-cable.html
Setup
270x sapphire vapor-x and or 7870 ghz shapphire (tried both)
3570k
z68 ud5h b3 (uefi flash)
12 gb ddr3
750w corsair tx750
Windows 7 Ultimate
etc
eleftft407 input is vga or hdmi
ns-39l700a12 input is vga or hdmi
Cables available to try
club 3d display to hdmi active
displayport to hdmi
multiple hdmi
2 dvi to hdmi
2 dvi to vga
2x vga cables
I'm going to post this on linustechtips, if I find a solution I will post here aswell.
Thanks in advance
i7Baby
BANNED
What ports are available on each monitor?
What Ports are available on the 270x?
What ports of the card have you got hooked up to what ports on the monitors?
Do you know the difference between DVI-I and DVI-D?
Johnabie
Monitors have hdmi and vga input.
270x has one display port one hdmi and two dvi in dvi-I and one dvi-d.
7870 has two mini display port one hdmi and one dvi
Tried every possible configuration.
I have the dvi to vga hooked up on dvi white, the port with both digital and analog signal.
Johnabie
dvi to hdmi
Johnabie
One of each, I also tried thru display and hdmi and dvi.
This is my card
http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1227&lid=1&pid=2036&leg=0#
2 thru dvi-i and 3 thru dvi-d
Johnabie
No it does not, i'm using a dvi to hdmi cable.
But it works just fine, i can activate any 2 of the three at anytime, just not 3 at a time.
I also tried
Setup
screen1 Dvi-i to hdmi
Screen 2 hdmi to hdmi
Screen 3 display port to hdmi
