I currently have a Global Win CAK 38 with a delta. The sound is pissing me off. I think I should either buy a 60mm YS tech fan or buy an 80mm fan with a converter to 60mm. I do not know if i can buy the here in Canada. I know that I can buy the ys fan in Canada. There is about a 10CFM difference between the ys and delta fan. What would that translate into degrees? How much higher would my temps go?
