A-DATA USB slow speed / A-DATA Recovery
EddieExecutor
135
Hy there folks ...
I've got an ADATA Sport Series 32GB Flash Drive (USB2.0 Portable) Model RB19 32G ORANGE and the thing is i get realy slow writing speeds ...
From start it goes 60Mb/s, than it drops to low as 1.5-3Mb/s in about 20 sec ...
I've got Win 7 Ultimate 64Bit
Is it possible since my MOBO has no Win7 drivers, only Vista that this should be the problem ???
MOBO: Asus P5W DH DELUXE
PROC: Intel Core 2 Quad Q6600 B3
GPU: Asus AMD HD6870 Direct CU
PSU: LCPOWER 6600, 600W
RAM: 2x2Gb PATRIOT PC6400 800Mhz + 1x2Gb ADATA PC6400 800Mhz
HDD: WD Caviar 250GB Sata 2
___________________________________________________
It's like 2gb of xvid movie transfers from the HDD to USB in cca. 15min ... it's rediciolus ...
USB is NTFS formated, 32Gb, duno what to do so i wanned to try ADATA recovery but i can't read the CODE on the USB since it's a bit faded.
What should i do and is this an USB prob or my MOBO USB 2.0 driver prob ...
Regards
EE
It could be driver related, who knows? I've heard of people installing maybe one Vista driver for a peripheral device (eg printer) on Windows 7, but using Vista drivers for the entire motherboard must be considered as a possible cause and is something I would never do.
Beats me why you installed Windows 7 knowing that it's not supported on that particular motherboard model.
I installed Win 7 as it came out in RC1 ... since than i had no probs at all, the OS even works faster than Vista ... anyways like most users i hate Vista aswell, just for notice WIFI driver on Vista is bugged, on Win 7 it works like a champ ... thats why i got Win 7 asap i could ...
