1. I plan on getting this system:
AMD Athlon X2 3800
XFX OC 7900GT
1GB (512MBx2) PNY DDR400 (from my current comp)
160GB SATA 3GB/s HDD
dvd burner
floppy drive
Aspire X-Plorer
Now the case comes with 2 80mm fans, do you think another 120mm will be enough cooling for the above system? And I think I will OC my CPU a little bit, but not much.
2. Now, I want to overclock the CPU just a little bit, to about 2.2GHz. I heard RAM is important in Overclocking. All I want is a tiny overclock to 2.2ghz, so should I be ok with the PNY ram? Or should I wait until I upgrade to 2GB and get higher quality RAM? BTW, I know you guys will say get an Opty 165, but I am getting a really good deal on this processor.
AMD Athlon X2 3800
XFX OC 7900GT
dvd burner
floppy drive
Aspire X-Plorer
