Hello,
I have planned my rig for a quite some time now. I have Chieftecs Super Series 750W power supply. I am wondering, if it could power GTX590, GTX260 (PhysX dedicated) and i7 3770K.
I will buy the GA-Z77X-UD3H-motherboard.
And now for the CPU cooling: which is better, Antec Kühler 620 or Thermalright Silver Arrow SBE? If neither of those is good, you can also recommend something. I use mainly a finnish computer shop (http://www.jimms.fi/). Yeah the page is in finnish, but it is not hard to find the search bar and try it out. The names are the same in there even though the page is in finnish.
After this I thought, that maybe the GTX590 and GTX260 will run quite hot. I will be using Fractal Define R4 as the case, so I'll maybe need some case fans. Could you guys recommend me some silent case fans, which would fit with the motherboard and the case?
Many questions in one post as this is my first one. I have followed this page for some time even though I have not registered.
