A few questions. LED, Contrast Ratio, Size.
griptwister
1,437
I would really like a 1080p (or i) monitor. And I would like to know what would be best...
I think I want a 23" (was going to buy 27" but Its out of budget 🙁 ) monitor, It seems to be the best priced, but is there really a difference between a LED backlit and non LED? Also, This contrast ratio... What would be overkill contrast wise. Also, is there any difference between x4AA and x8AA at this resolution?
LED backlighting is better than the common florescent tube backlighting.
Contrast ratio is hard to compare from model to model, so I would not worry about it.
Whether you can see much difference between x4AA and x8AA is up to your eyes and brain 😉
