Can I attribute my poor overclocking to the fact that at present, my PSU is 200w short of the necessary 700w power for this kind of system and is not a high quality PSU able to provide steadier voltages?
Assuming that for a successful overclock I need to increase the voltage beyond what this psu can supply. I have an OCZ midstream 700w on order. I know temperature can be an issue, but I turn the case on it’s side and remove the side panel (as this is not a permanent solution but increases airflow massively) just to see if it’s stopping me and it appears not to be a strong causal factor in this situation.
Am I supposed to have access to the CPU clock on my motherboard as I now have access to everything else?
Why does my motherboard only see the RAM as being 800mhz and not 1111mhz as is stated on the box (I thought there was a way to make it see this for 680i motherboards) and furthermore if I try to increase it to 1111Mhz it asks me to lower the settings by quite a bit. The overclocking potential for the RAM and possibly FSB is extremely mild whilst the CPU’s (via the multiplier) is based on the lack of airflow and overall heat..
How capable is my Zalman CNPS 9700 LED at overclocking a quadcore CPU (as it was not included on it’s CPU cooling list and at best is 52c idle) but I’m thinking of going for a more up to date cooler?
These are all my components and setup:
BFG Nforce 680i motherboard Intel QX6700 Quad core
4x1gb Corsair Dominator CM2X1024-8888C4D
Inno3D Geforce 8800GTX 500w
Xlico PSU
4 regular sata HDD 2 DVD drives
1 front 12cm intake fan and 1 rear 12cm exhaust fan
WinXP SP3
A photo of my setup (in need of some extra cooling and cable tidies)
http://i108.photobucket.com/albums/n...2/computer.jpg
My bios screen (CPU speed inaccessible)
http://i108.photobucket.com/albums/n20/contactadam2002/030920091756.jpg
http://i108.photobucket.com/albums/n20/contactadam2002/030920091757.jpg
The bios bootup screen
http://i108.photobucket.com/albums/n20/contactadam2002/030920091764.jpg
Xlico PSU
WinXP SP3
