A huge problem!
Domantas_4
6
Ok, so Im getting a new GPU - RX480 4gb, and i've looked up, and all of my parts will work fine with it. So i ordered it yesterday. But just right now i realised that i should check pin's, and it happens to be that RX480 has single 8pin, and my power supply and old GPU used dual 6pin... what should i do guys??? My PSU is "Codegen 600 X". Please help!
Some might suggest using an adapter but I won't. One, that's a cheap power supply. I'd have bought a new, decent power supply before I bought a new videocard. Two, that's a pretty good videocard you got, why risk it by not using the proper power supply?
If you can cancel the order, do it. Then either choose a 6 pin videocard or think about upgrading your power supply.
Yeah, i asked some of my mates and they suggested buying new PSU, but they have no idea which... my motherboard is Gigabyte Ga-b85m-d2v. I know its quite an old one, but i checked that RX480 and it will work together. Could you recommend a PSU thats is decent, but also not too expensive?
