A little help folks
muffledBeat
Commendable
Sep 18, 2016
4
Hey folks! I want an upgrade gpu but dont know if it fits to my system.. Current system:
athlon 860k (yup its crap)
a68hm-k
geforce 750ti (mini..)
8gb RAM 1600mzh
psu 500W (dont remember firm but nothing special)
I wanna buy 970 or 1050ti but dunno which fits better my system?
The 860K is still a solid, entry-level CPU and, provided you're realistic with expectations, should still serve you fine.
An OC on the 860K would likely help you out some, but I don't think that's possible on the A68 board...... and the potential gains are not worth the investment in a new board.
Something like a 1050TI should be a pretty solid pairing - although the 860K may hold it back in some instances but, overall, a solid improvement over the 750TI.
Without knowing anything about the PSU, it's hard to say..... but the TDP of the 1050TI and 750TI are the same so *should* be fine.
The 970 is an additional 70W TDP over the 750/1050TI, so I wouldn't risk it without exploring the PSU first........ and the 860K @ stock speeds would...
The 970 is an additional 70W TDP over the 750/1050TI, so I wouldn't risk it without exploring the PSU first........ and the 860K @ stock speeds would likely restrict the 970 in most situations anyway.
