A little help on my build please :)
jakob111
43
hey im building a PC for my friend as a gift and i wanted to ask you if the pc works and is compatible or you would change something let me know as well budged 600euro! (sorry for bad english im from portugal ^_^)
the only parts i still need are on this list and im not sure if i should buy them or other parts
power supply: Corsair Builder Series CX 80+ Bronze 500W
CPU: AMD FX 6300
GPU: need help on this one
Motherboard: Asus M5A97 EVO R 2.0
ram: Corsair DDR3 8GB 1600MHz Vengeance Black Heat Spreader
tell me please if you would change somthing and or if this build would even work thanks in advance .
Go to the motherboard manufacture website, find your motherboard, then find where you can look up what is compatible with your motherboard. Start with that. Everything you put on that motherboard has to be compatible otherwise you will have major problems.
i have a computer myself i build it , but this one is not for me its for a friend becous i cant ply alone its really boring thats why im giving him one but i just want to know if those parts are compatible or not and or if you would use an other GPU or if the gtx 960 is fine
yha i dont want to spend more than 800 euro on the build i have to buy him a screen too, the stuff is compatible i looked it up, do you have eny other GPU in mind ? cos the gtx970 is too expensive i have one myself its awesome i know but yha dont want to spend more than 800 euro
