So recently I got a NETGEAR Wireless Router (N600 Dual Band Gigabit (WNDR3700)) to use with my Gigabit port. The problem is that when I hook my Desktop (via Ethernet) to the router my mbps caps at 300mpbs -ish. Not bad, but when I have a direct line to the wall I'm going at 980mpbs -ish. Any fix for this? Do I need to do something?
All Ethernet cables are Cat5E for the record. The router says it supports Gigabit Ethernet so I'm not sure what the problem is...
EDIT: To be more specific I live in a dorm that has an ethernet port in each room, with mine happening to have a gigabit capable port (due to a specific request). It's safe to assume my source is fiber.
Using Speedtest, I can't pass 300mpbs up/down while connected to the router, but if I just do a direct connection to my ethernet port in the wall I hit 980+ mpbs up/down everytime.
