A little help
para123
38
Hello. I am currently playing my games & streaming, on a pretty old pc. Its a AMD FX 4100 cpu
GTX 550 TI gpu
8 GB ram
AsRock 970 Extreme mbo
And a fresh installed windows 8.1.
My question is : now when i have win 8 installed over my old win 7. Do you think it will increase my FPS for a little bit while gaming&streaming ( league of legends ). Do you think i will feel some sagnificant difference? Or everything will the same like it was on windows 7? Thanks
Everything is going to be more or less identical to 7 in terms of performance. Even if you decide to upgrade again to 10, it won't really help too much.
You may notice the slightest performance boost but to honest you wouldn't see anything that great even if you went to Windows 10. If your looking for a significant FPS boost you would have to upgrade your hardware rather than software.
