A little help
daggerous
4
Im about to upgrade my cpu mobo and my rams
Thinking of buying ryzen 1600 or 1600x,i would like some help with the best mofo and some ram kits 8gb or 16gb dual channel
Budget will be around 400$ - 450$
id like some compatible mobo and memories for the above cpu,gonna ultra gaming and multitasking
btw is the ryzen a good choice?
If you think you'll do a good amount of editing the ryzen may be for you. But if you're mainly gaming with light editing the 7600k may be a better option for you.
Gaming wise get Intel. It has better single core performance and will give you better fps. But like I said, if you do editing ryzen will beat intel
