Hello All,
I've lurked for a while and have already learned a lot by reading threads and stickies already provided. Anyway, I'm working on my very first build and would like some feedback. For example, am I getting the best parts for my money? Are they compatible with each other? Am I a total moron?
I will use the template provided.
APPROXIMATE PURCHASE DATE: As Soon As Possible
BUDGET RANGE: $1,500-1,700, Before Rebates, and NOT COUNTING Monitor/Keyboard/Mouse/Standard peripherals
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT:
1) Heavily using Photoshop/Lightroom/Photomatix to process and render HDR images and other Raw Camera files. Lots of filters and working with images at full resolution.
2) Heavy standard use: Office, Web, organizing/listening to music.
3) Occasional video editing (trying to learn Adobe Premier).
4) I also would like the ability to record and edit high-quality audio, sort of like a mini recording studio.
PARTS NOT REQUIRED: Keyboard, mouse, monitor, speakers, printer
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, Amazon.com, any other reputable and affordable sellers
PARTS PREFERENCES: I would prefer an Intel CPU. Other than that, I am not married to any of the components listed below.
OVERCLOCKING: Maybe after I learn more, but not now.
SLI OR CROSSFIRE: Again, maybe in the future, but not now.
MONITOR RESOLUTION: Do not know.
ADDITIONAL COMMENTS: I plan to use a smaller HDTV as my monitor, in the 24-32 in. range. So, I'd like the ability to watch TV on the computer as well. I would like the machine to be used also as an all-in-one media center, to watch HDTV, DVDs, etc.
Here is my actual planned build:
Intel Core i7-960 Bloomfield 3.2GHz LGA 1366 130W Quad-Core Desktop Processor Model BX80601960
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115224
ASUS P6X58D-E LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
CORSAIR XMS3 12GB (6 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model HX3X12G1600C9 G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145235
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
SAPPHIRE 100296HDMI Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102855
Western Digital Caviar Blue WD10EALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
(Planned storage drive)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136534
Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
(Planned OS/Programs drive)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136296
Creative 70SB073A00000 7.1 Channels 24-bit 96KHz PCI Interface Sound Blaster X-Fi XtremeGamer
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102006
Pioneer Black 22X DVD+R 8X DVD+RW 12X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 40X CD-R 32X CD-RW 2MB Cache IDE CD/DVD Burner LabelFlash Support - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827129043
NO CASE PICKED OUT YET!
Concerns:
I have several things I wanted to ask the community.
1) Can I do the RAM as I have planned above? The mobo I picked out has 6 memory slots, but it also has triple channel support. This was the most confusing thing to me. Can I do the 6 sticks as planned, or can I only do 3 sticks?
2) Is the Creative sound card overkill? I've always used an Audigy card in previous systems and have never had complaints. Is onboard audio nowadays good enough to not use a sound card?
3) Is the VelociRaptor a good-enough boot drive, or should I splurge and get an SSD?
4) Is the PSU too strong? I tried using an online power supply calculator and it seems it may be too high wattage.
5) It seems the video card is the weakest component. Do I need a better one if I POSSIBLY want to watch HD television on the computer, or edit HD video. Again, I plan to use an HDTV as a monitor, 24-32 in. in size, or a dedicated monitor if that's a better plan.
Thank you all very much, I apologize for the length of this post. But I'm a newbie needing some help from all you experts. Any help or advice is greatly appreciated!
Concerns:
