Question A problem in Hp 6005 pro small from factor
Aug 2, 2025
4
So I was using the pc Normally and shuted it down
After like 30m i started it and there were 9 beebs i knew that its from the ram
And i tested them one by one and still there were the beebs
I removed the The battery and I returned it after that the beebs gone
But there is no display or even booting
The pc is on but died idk how
Need help pls
Ty
Given the system's age, it could be a number of things that may have failed. Most likely is some component on the motherboard itself has failed.
Have you examined the motherboard for any physical damage (swollen caps, for example)?
Everything is alright ithink
IT was 30m between the last time i used it
It happened suddenly for no reason.
