A problem with my new PC I need help with
inaccurate2
4
I have had a problem with my new PC, when I start Windows 10, it says that my ethernet connection is limited and that it has no connection, even though it is properly connected, I was wondering if anyone could help me fix my computer?
at this point I have to assume to op doesn't have a DVD drive in PC, and since most hardware makers aren't giving away USB sticks yet, its a catch 22.
At op, can't you ask a friend to help? don't you know anyone with a PC and internet? All you need to do is go to web site for motherboard and download the latest LAN driver, put it on a USB and install it on your PC. Then it will hopefully fix your problem.
Did you install your ethernet driver?
I can't, I don't have any Internet connection
Did you install the drivers on your motherboard's included disk? Some way or another, you need an ethernet driver.
No, I didn't, how do I install the correct drivers to my hard drive? I don't have Internet access on my PC
Install all the drivers that are on the disk. And then when you're on the internet, update them.
How do I do that?
At this point, I think you need to read the instruction manual that came with your motherboard.
