A question about fan connectors
BestRivenNA
8
Would all of the fans that comes with the Corsair 500R Carbide series connect to the ASRock Fatal1ty Z87 Killer LGA 1150 Intel motherboard? I'm a newbie to computers so I don't know if it could. Thanks for all the help!
The only issue you'd have with fans transferring over is number and size. All they need to work is a power connector, most are three pin. All current motherboards come with the same power connectors for fans so this isn't something to worry about. Fans are super easy to work with, just plug and play. Don't stress about it.
