A question about Fan Push and Pull placement on a 280mm CLC.
Alexandrious1
105
I wanted to ask, so my EVGA 280MM CLC, it came like this where the left 140MM Fan is pulling air from inside the case, while the other fan, seems to be taking heat from the radiator and expelling it into the case. Temperatures in the case seems Low. CPU Coolant at heavy load stays around 38C. Processor which is a I7 7700k Oced to 4.8GHZ goes around 55 to 68C Max. Thing is, the part of the radiator thats pulling air from within the case, always feels cool to the touch, while the other end, which is at the end of the case, the one thats pulling hot air from the radiator and expelling into the case, seems to always be warm.
I have 4 140MM Fans pulling air into the case, while I have two 140MM Fans pushing warm air out. my two GPUs in SLI are both liquid cooled pulling cold air from within the case. Mobo ambient temps seem to stay around 26C. Should I make any changes to the configuration you think?
Edit: Also my room temperature stays around 65F.
Nay you misunderstand. I have one fan, with the EVGA E shown on it facing the proper direction hence its E, while I have its other 140MM Fan on it, backwards, thus showing no E. I dont recall why I did that, I think I did to have one fan Draw out heat from the Radiator, while the other Fan pushes cold air from within the case into the radiator. Is coolant temps of 32-38C normal?
