He is a scenario...
I have an AMD fx 8350 stock clock and r9 280x stock clock in a crossfire configuration. Obviously, there will be a bottleneck on the processor, so i need to turn on Vsync because i dont want to overclock and so there wouldn't be a bottleneck on the processor. Lets also say the monitor runs at 60hz.
I heard that if your system cannot output 60fps, it will cut it down to 30fps (half) when running Vsync and so on.
So lets say i play a game and normally i would get 100fps with the crossfire at 50% utilization and the 8350 at 100% utilization. There is obviously a bottleneck and so i turn on Vsync. FPS now matches 60Hz at 60 fps. Now crossfire uses 30% utilization and CPU uses 60% utilization. Then i run into a firefight... here is the question:
Will the crossfire and CPU increases its utilization to try to keep the fps at 60 fps?
Im sorry if this is a stupid question, but im quite new to this Vsync stuff.
p.s. All these percentage are just made up numbers
