Question A Ramaxel memory will work in dual channel with a HyperX Impact?
Nov 27, 2019
Hello, I want to upgrade my RAM memory from 8GB to 16GB. I have this memory:
RAM: Ramaxel DDR4 1RX8 PC4-2666V-SA1-11
I dont know if a HyperX or a Crucial RAM memory with the same specs DDR4 2666MHz 8GB will work without problem and if they will work in dual channel. Any help will be appreciated. Thank you in advance!
13thmonkey
They might, they might not. They'll work and you'll be happy, or they'll work after many hours of fiddling with settings and you be pleased to beat it, but dreading a bios update, or they not work even after hours of fiddling with settings and you'll be fed up.
What's your time worth? Only sticks sold in packs are guaranteed to work together, everything else is pot luck or sweat.
