"A Required CD/DVD drive device driver is missing" halting installation
Iamthewalrus
48
Hey everyone. So basically I'm trying to install Windows 7, more specifically Windows 7 Ultimate 64-Bit, but this little issue is halting everything. It won't let me progress unless I insert a driver disk or something of that sort for a CD/DVD driver, which I don't have. I've tried the USB port swap method, I've tried disabling all of the USB 3.0 slots, (which I now have re-enabled), and various variations of those things. I have no other ideas, and I have to do this for my computer to work. What do I do? This is on a new ASRock B250M-HDV motherboard with it's default, out of the box BIOS, (no drivers yet), and the Windows 7 copy is on a USB. Thanks.
What do you mean by the first suggestion? Like, install from a disk? And would integrating my copy of Windows 7 with that Windows 7 USB Patcher from ASRock's site allow me to continue my installation without the issue in the title? Thanks for the reply.
Yes - that's one option.
You integrate USB drivers with Windows 7 USB patcher, not USB patcher itself. But yes, that would allow to install windows 7 from usb.
Okay, I'm sorry but I just don't know much about this stuff. I think I may have phrased that badly. What I'm gathering is that I download the patcher from the ASRock website, run it, and direct it to the USB with my Windows 7 copy on it? Or at least, something like that. I need a bit of guidance on this process, this is all foreign to me. Thanks again. I know it's a lot to ask, but I need something of a walk through for this. I'd be very grateful if you could help.
Okay, I'm trying to run the application but it says "Entry Point Not Found - The procedure entry point InitializeConditionVariable could not be located in the dynamic link library KERNAL32.DLL." I cannot believe I'm having more issues, I just want my computer to work.
Sorry, disregard those last two. Got it working on an old laptop.
Is it normal for it to take a long time to add the driver to the images? It says it may take a couple of minutes, but it's been far longer than a couple of minutes.
