Check here for the CPU-Z Specs when I got Windows 7 to work somehow:
Click Here for my Computer Specs
Motherboard: ZEB - 945
CPU, RAM and HDD have to be like 9 years old.Motherboard is relatively new and was replaced about 3 - 4 years ago.
PC has exactly 3 OS: Lubuntu,Windows 7 ,Windows 7.
This BSOD has been haunting me for about an year and a half, I couldn't find a solution myself.Searched a lot but nothing helped.Many seem to say that this BSOD is hardware related but Lubuntu works with this PC flawlessly.I believe that should strike out the 'hardware fault' possibility.I hope you guys can find a solution for this problem.
Let's get to the BSOD.
This Blue Screen occurs during the startup.The black screen with the Starting Windows text appears but those flying balls of color which eventually make the Windows logo don't.After some seconds, this happens:
STOP ID: 0x0000005C (0x0000010B, 0x00000001 ,0x00000000 ,0x00000000)
This BSOD can be bypassed easily but it still remains clinging with its hectic after-effects.
It is bypassed by disabling ACPI APIC Support in the BIOS.But it leaves the OS to work with only a single core. BUT Lubuntu works flawlessly with both cores functioning when it's enabled.But, Windows 7 doesn't, it gives me this BSOD all the time.
Here are the screenshots (Lubuntu):
Single Core (ACPI Disabled)(Right) + Dual Core (ACPI Enabled)(Left)
Lubuntu works fine but Windows encounters some critical problems.
I tried the Hotfix from Microsoft.Unfortunately,it didn't work for me.
Here's the article.
Here's the Hotfix.
I tried All Safe Modes and Windows Installation CD too during the BSOD.All lead to this dead end.
I can't get the dump file.I tried changing the pagefile capacity, creating a Minidump folder.Dumpfiles are nowhere to be found.I hope the provided information is sufficient for finding the fault.
If you have reached till the end of this post, thank you very much for patiently reading the whole thing.
Thank you for the support!
Related Thread: Insane Core Temp
Here's the article.
Here's the Hotfix.
