A strange problem
innerchaos
25
Hey guys.
First of all, my specs:
CPU Type:
AMD Phenom II X6 1100T
CPU Speed:
3.37 GHz
System Memory:8GB
Video Card Model:
AMD Radeon HD 6970
Video Card Memory:2 GB
Motherboard:Gigabyte GA-870A-UD3
I've been having disgustingly low performance in all games since last week.
For example in WoW fps often drops to 10-15 for a couple of seconds and goes back to normal, then drops to 10 fps again.
I tried every single game and the results are all the same.I'm getting extremely low fps even in Deus Ex:HR.
I was using AMD 12/10 drivers then rolled back to 12/8.It didn't fix the problem.I ran some CPU tests with OCCTPT and found no errors.
My GPU activity is around 59% and CPU temperature is around 57 degrees when I'm playing Battlefield 3 but fps is around 10.
I tried lowering all settings, it didn't matter.
I formatted my HDD and re-installed windows two times.
I'm clueless right now, i'd appreciate any help.
And oh, this started happening a couple of days after I upgraded to Windows 8 (64 bit)
innerchaos
25
Some more info
Programs running in the background:
AMD CCC
Kaspersky Internet Security 2012
Realtek HD audio manager
The weird thing is that this doesn't happen all the time.It happens quite often but sometimes it just stops and i get 50-55 fps in battlefield 3 again with ultra settings.
blacknemesist
490
98
18,890
Looks more like a GPU burning up really.When the Temps on a GPU reach a certain number the GPU downclocks itself to cooldown.Get HWmonitor and run it then run the game.HWmonitor will record your maximum temperature.
It can be a case of poor air flow in the case or the GPU fans are broken,check if they are running.
It wouldnt be a bad idea to check your ran using memtest86+.
It could also be that your HDD has alot of bad sectors and when it tries to acess those the performance slowsdown.You can't fix bad sectors as far as I know but you can use another HDD and try it out.
Make sure your GPU Pci-e connector are well connected to the GPU.
Lastly you can open the computer case and get a huge fan on maximum speed pointed directly to the computer and check if the hangs still occur.
My guess is an overheating GPU dropping performance to rid itself of the heat.
innerchaos
25
Hi
My old HDD was failing and I replaced it and i ran crystaldiscinfo and it found no problems.
Here, maybe this graph could help.
innerchaos
25
I just tested it again in WoW.Still encountering random freezes.
GPU activity was around 40% and temperature was around 49-52 degrees.
I overclocked the GPU to find out if it was really downclocking itself.
