A upgrade for Radeon HD 7770
Dragonsbane11
45
I am looking to upgrade my GC and wanted to get an opinion on what I can get away with. Its tax time so not a big budget concern, but I really dont want to upgrade my PSU if I dont have to. Below is what I am currently running.
AMD FX-8150 3.6GHZ
2TB SATA III 6GB/S 7200RPM 64MB CACHE 3.5" HD
4GB CORSAIR VENGEANCE 1600MHZ DDR3
ASETEK 510LC 120MM WATERCOOLER
LG 24X DVDRW
ASUS M5A97 LE AMD970A AM3+ USB3 SATA 3 MB
CORSAIR 500 WATTS CX500 V2 80 PLUS POWER SUPPLY
AMD RADEON 7770 1GB DDR5 PCI-E 3.0
Any recommendations?
Alright, stop right there. That PSU has enough power delivery for a 7970, BUT, its caps are crap, so running it at the load that a 7970 would need can cause serious reliability issues. This is the issue with the V1 and V2 CX series PSUs. I recommend replacing it with either one of the V3 CX series models with sufficient power delivery (500W to 600W) or a different model such as an Antec Neo Eco 520W or an XFX 550W or some other such model with better reliability under heavy load, so there are good options around $45-65.
If you don't want to upgrade the PSU, then I suggest not going for something more power hungry than a Radeon 7870. Even that might be pushing your luck over a few months.
You might want a PSU upgrade if you went with a 7900 series and did a monster overclock on the 8150, but at stock speeds. A 7900 is going to take about 200W under full load and your CPU about 125W. So that's still only 2/3 your PSU output.
Fans, HDD, etc probably total another 50-75W. You'll be fine.
totally agree
Bah that is was I was afraid of....I hate replacing PSUs...... I was hoping to go up with out needing to put a new PSU in.
Well, a Radeon 7850 shouldn't be an issue and it's still a big upgrade fro ma Radeon 7770 😉
If you want more than it, then a PSU upgrade would be a good idea.
Ah ok, thanks....Sorry to ask but any specific one I should pick? Not sure what the best one would be.
http://www.superbiiz.com/detail.php?name=AS-785DTV2&c=CJ
This is the best 7850 AFAIK. It has the highest GPU frequency overclock and a considerable memory overclock (and the full 2GB of RAM capacity unlike some of those 1GB models) along with what is supposedly the best cooler for manual overclocking on the 7850s. It's also not much more expensive than the cheapest 7850 2GB.
Awesome! Any reason why it is OOS most places though? (Newegg, Amazon)
Oh I can wait, lol. I just wanted to make sure it wasn't out of production or anything, Ill grab it when its in stock again, im just not that familiar with Superbiiz. If its the best one Im sure it will be worth the wait.
Although it does show Discontinued on Neweggs site....
If thats the best one then I shall bite on it, I see some good reviews about the site around here. Unless you think there is a better card for my situation....... 😛
I bit, I shall let you know how it works for me, Thanks for all the help! 😀
