A white led is showing because of vga
FlameDrop13
65
I have built a computer and it won’t show anything on the display.
I have a gtx 1060
Themaltake 600w
Amd ryzen 5 2600
I’ve tried unplugging it and plugging it back. Pretty much everything except for getting a new one plz help
MERGED QUESTION
Question from FlameDrop13 : "Asus Strix B350-F Won’t Boot For The First Time"
MERGED QUESTION
Diagnostic LEDs are usually placed near the component that they monitor. In this case they are saying there is a problem with the RAM.
I would recommend reseating the RAM. Remove the RAM sticks one at a time, clean the contacts, blow out the slot, firmly install the stick, and then repeat for the rest of the RAM. Make sure that matched sets of RAM are in the same color coded slots.
Then reboot.
I’ve done that already I think I need to update bios. Do u think so?
Cuz I have to take a r5 1500x outta mine and put it into my friends pc which is a big hassle. I have to buy thermal paste..
But do I think Canada computers can do it?
Put the old CPU in and then reinstall the CPU cooler. Then go to the manufacturer website for your specific motherboard. Then under the support menu, download the the latest BIOS to the root directory of a USB flash drive. Then follow the instructions in your manual to update the BIOS.
