Hello,
I recently asked you guys if I should replace my thermal paste due to there being a tiny bit over the edge. I just took of my hyper evo 212 and used both articlean products to clean my CPU. This time I put less on and it hasn't gone over the edge however, temperatures or no better. It still idles at 45 C and reaches 78 C under maximum load with prime 95 according to speccy but Easy Tune 6 says it only reaches 51C? . I have disabled the APU as I am using a discrete card. Should I use push pull and if so how would I plug in another fan? Do theyy have to be the same? I am really confused.
Thanks!
Thanks!
