A10 7800 + R7 250 dual graphics low FPS on DOTA 2
knivespico15
60
I've review some AMD A10 dual graphics set up, playing DoTA2 at 1080p having max settings, on youtube and notice that their FPS are above 45FPS. I have an A10 dual graphics too but my frame rates were only averaging at only 27-35 only...
I don't know where the problem is, I already installed the AMD latest drivers and did some tweaking in BIOS to speed up my ram... Enabled both dual graphics in BIOS and AMD Radeon settings... But, results were still the same...
Need help from experts here...
Set-up
OS : Windows 7 Ultimate 64bit
MOBO : MSI A88XM-E45
CPU : A10 7800
GPU : Sapphire R7 250 DDR3 2GB
RAM : G.Skills Ripjaws 2133C10D 16GXM
Thanks a lot The Grox Empire... Actually I'm thinking of upgrading my GPU... I'm tired of dual graphics mediocre performance... I'm selecting either r9 380 ITX of Sapphire, or R7 370 4GB Gaming of MSI... Which do you think is highly compatible with my APU A10 7800?
I got a Fractal Design Integra M R3 650W... Doesn't have problem with it... By the way, another question sir, will my AMD APU A10 7800 bottleneck the r9 380? Hoping it would not...
Not the best PSU but can do the job. Depends on game, if you play Moba it wont at all, except for Heroes of The Storm because it use SC 2 engine (need high physic for high gameplay). On MMORPG it will hold back your performance, on big scale war game like ARMA 3 it's unplayable. Bottleneck are thing that shouldn't be worried, you can always upgrade laters. It's still massive performance upgrade even only GPU
Thanks a lot for all the replies and advices... This afternoon I've ordered an R9 380 ITX of sapphire... It will gonna arrive next week.
Also, I will change my UPS 600VA soon, b'coz for sure, this won't support my PSU with 650 watts...
