bornthuggin804 :
i have the a6 with the 6670 also. how do i disable the onboard graphics and just use the 6670
You dont want to disable the onboard graphics,dual graphics will give you about a 40% boost if done correctly
If its done corectly then the onboard vidceo output from the motherboard will give no signal & youll have to use the 6670's video outputs to your monitor/tv
If you have dual graphics installed & are still using the onboard video outputs then its setup wrong,it will default to the onboard instead of the 6670 if a game/app doesnt support dual graphics configuration - what you want to do is enable the 6670 as the primary card
The way to do it is this
Ill assume you already have drivers installed for both 6670m & the onboard installed
If so boot into the bios
Northbridge settings
Put the graphics adapter as pci-express
in the dual graphics option set it to enabled (not auto)
Save & exit bios
If the pc boots & you get video from onboard,then let it boot into windows,open catalyst control centre ,disable/enable/disable dual graphics a couple of times
Make sure its disabled at the last press
Then shut down your pc
The next time you boot you should have to use the 6670 video output instead of onboard - this is now setup correctly
Enable dual graphics in ccc now & yuor good to go - there are a couple of games that prefer dual graphics disables - need for speed most wanted & special ops the line - thats about it though
& to the poster above - a3670 with a hd6670 in dual graphics mode will play BF3 at 40fps medium settings in 720p res - thats a fact ;-)
