a64 3500 159 fahrenheit need help
shaido7
175
I just purchased a64 3500 thermalright 120 and 120mm panaflo fan msik8neo platinum 2, i also have a thermaltake xaser 3 case. I bought this equipment a week ago and im just now having problems the msi monitor says core temp is 77f if my calulations are right thats 25 degrees celcius which i think is an ok temp but when i load up lineage 2 and shoots up to 159f about 70c.what do you guys think i should do to fix the problem?
pentium 4 3.2
oczpc3500 el ddr platinum matched ddr433
western digital raptor 74 gig 10k rpm
8knxp gigabyte
geforce 4 titanium 4600(i know get a faster card)soon!
shaido7
175
ill have to check that ,meanwhile i pulled off heatsink started from scratch and got same results,then i switched to factory heatsink and got same temp so im not sure what to do now also i ran fanspeed and it verified my core center.
pentium 4 3.2
8knxp gigabyte
shaido7
175
yeah it was a steady 39-42 for 10 minutes
pentium 4 3.2
8knxp gigabyte
