My first Post so hopefully I provide enough info for you all
System Specs:
Mother Board - ASUS A7V133
Processor - AMD Athlon 1.0 GHz Thunderbird 266 FSB
Cooler - GlobalWIN FOP32-1
Graphics Card - ATI Radeon 32Mb DDR LE AGP
Power Supply - Sky Hawk Series A8-95 300 Watt (AMD Aprvd)
All of the above were purchased new in the last 2 weeks.
Hard Drive - Quantus 6gb/UDMA 66/5400
- Using until Maxtor 40gb/UMDA 100/7200 arrives next week
Memory - (2) 256Mb Crucial CL2 Sync 100Mhz
- Using until 512Mb 133 arrives next week
Once everything was installed and I booted for the first time I have incurred the following issue:
Issue - I formatted the hard drive and made it bootable. From there I tried to install Windows 98 and the trouble starts. I get three short beeps and then the screen goes blank. If I hit a key the system beeps once and then it proceeds farther into the install. It will proceed at random lengths of time and then do the same thing. If I keep hitting the keys it will go all the way through the install procedure.
Solutions Tried:
1) Windows 2000 instead of 98 - similar results
2) PCI Graphics Card instead of AGP - similar results
3) Changing Keyboards (not USB)
4) Changing Mouse (USB)
5) I have been through the manual pg. 45 Beep Codes, no listing for 3 short beeps
6) Tried reseating the Memory and Video Card.
- After rebooting and starting 10 times it appeared to work the first 5 then on 6,7,9,10 the beeps returned. With boots 9 and 10 getting the beeps more than once.
- On the occassions where Windows would boot I tried doing some simple activities, defrag, code scan, Directory tree and then the system would freeze on me.
- After 10 boots the CPU temp was running at 52.5C previously it was in the 45C range.
Now to the question, does anyone know what the 3 short beeps signify on this motherboard. Or do you see another issue that may be causing my problem.
Thanks for any help you can provide
<P ID="edit"><FONT SIZE=-1><EM>Edited by jlind23 on 04/15/01 05:02 PM.</EM></FONT></P>
System Specs:
Solutions Tried:
