Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
Try this beta from the german ASUS FTP site, just save as and get it
and try it
The german site allways has the latest bios and everything why is Asus
German ?
Its 1015.033 beta
just make sure you get the right one
and i do
think its newer ?
Hope this helps, have not bothered getting anymore bios upgrades no
point now :0 am thinking of getting a Xp 3200 and a NForce 2 Ultra
board though to see me though MANy years, though my A7v266-e like
yours butonly with a Xp 2400 will do me gine i think before the 64bit
systems take hold and come down in price
and dominate everything.
Hope this works BUB
On Wed, 9 Jun 2004 14:43:13 +0000 (UTC), Scott Zabolotzky
<zabolots@ripco.com> wrote:
>Yes, I'm sure it's the 266MHz FSB version. Here's the breakdown of
>the numbers on the chip:
>AXDA 2600 D K V 3 C
> | | | | | | |____Maximum System-Bus (Front-Side-Bus)Speed(FSB,D=333,C=266
> | | | | | |______Level 2 Cache Size(?? L2 Cache=256kb)
> | | | | |________Maximum Die Temperature(Die??,V=85?,T=90?,S=95?)
> | | | |__________Operating Voltage(Nominal Core Voltage)(????)
> | | |____________Package Type(????.D=OPGA??,A=PGA??)
> | |_______________Model Number(????)
> |____________________Processor Core Architecture/Brand Name(??XP 0.13??)
>Thoroughbred-B Athlon AMD XP 2600+ 2.133GHZ, 256KB Cache, 266MHZ FSB
>AXDA2600DKV3C
>Scott
>We Live for the One we Die for the One <Mr fred@yahoo.com.au> writes:
>>Are you sure its a 266mhz fsb version
>>I think you might have a 333fsb version.
>>Not sure what it would do if you installed a 333fsb cpu maybe whats
>>happening to you now.
>>I was to wanted a 2600 but alas none in my country so i settled for a
>>2400
>>Theirs some numbers on the chip write em down and do a google to see
>>what fsb version chip you have.
>>On Wed, 9 Jun 2004 10:17:37 +0000 (UTC), Scott Zabolotzky
>>>I've got an A7V266-E with BIOS version 1011. According to the Asus
>>>web site this MB is supposed to support CPU's up to the 266MHz FSB
>>>version of the Athlon XP 2600+. I bought one and when I put it in
>>>the PC and turn it on nothing happens. The power lights come on, the
>>>drives spin up but I get nothing on the screen and no POST beep
>>>codes. Do I need to do anything to get the PC to recognize the new
>>>CPU other than just installing it and booting up? When I put my orig
>>>CPU back in (Athlon XP 1900+) it boots right up.
>>>Any ideas?
>>>Thanks...Scott
