A7V600 - low voltage problem
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi!
I have been using the A7V600 for a couple of months without problems
now. But a few days ago my machine developed the problem that it froze
up just minutes after booting.
Using Asus Probe I have now traced the problem to low voltage on the
3.3V line. It starts off at 3.2V and continually drops. When it drops
below 2.8V, the machine will eventually freeze up.
What could be the problem? The PSU, the mainboard, too many PCI-cards or
one card using too much power?
My curent setup:
A7V600 mainboard
PSU: Thermaltake III Silent Purepower 480W (about nine months old)
CPU: XP2700+
RAM: 2x512MB KingMax PC3200
AGP: ATI AIW 9800 Pro
PCI: Soundblaster Audigy
PCI: Netgear Wireless LAN WG311
PCI: Adaptec IDE RAID Controller 1200A
PCI: Adaptec SCSI Controller 2930U2
TIA,
Stefan
Paul
Splendid
Mar 30, 2004
5,267
In article <407a2941$0$27643$61ce578d@news.syd.swiftdsl.com.au>, Stefan
vom Bruch <stefan@vombruch.com> wrote:
> Hi!
> My curent setup:
> A7V600 mainboard
> CPU: XP2700+
> TIA,
> Stefan
Your PCI cards consume relatively little power. The video card
can be up to 70W while playing 3D games, much less in the
desktop. One estimate is 12V@1.5A and 5V@10A for a 9800 or 5950
class video card.
Either something is wrong with the PSU, the ATX 20pin connector
is not making good connections, the ATX 3.3V sense line has become
disconnected, or there is a partial short somewhere.
Many (but not all) ATX PS share the energy of the same primary
transformer winding. Output voltage is established by the turns
ratio of the output windings. The ATX connector has a 3.3V pin with
two wires joined to the same pin, and one of the wires is a remote
sense. When the remote sense detects the output voltage dropping,
it instructs the primary to "crank it up".
Typically, when one output is overloaded, you'll see the other
outputs rise higher than nominal. This happens as long as the
power supply is still under closed loop (feedback) control.
You don't mention how the +5V and +12V are reading, so I cannot
comment on whether this confirms a particular diagnosis or not.
Since so many people have trouble with their power supplies,
the odds right now are that the PS needs to be replaced. It is
either that, or somehow the ATX connector is not working properly,
to carry the current from the supply into the motherboard. Try
unplugging and replugging the ATX 20 pin connector.
HTH,
Paul
john
Splendid
Aug 25, 2003
3,819
On Mon, 12 Apr 2004 15:37:59 +1000, Stefan vom Bruch <stefan@vombruch.com>
wrote:
>Hi!
You probably know the answer to this one yourself. The power supply has
obviously got to be the first suspect... maybe the cheapest too.
If that doesn't do the trick I would be inclined to pull all the cards out...
just in case one of them is pulling the line down, and lastly the mobo.
John
G
Guest
Guest
>> Hi!
>class video card.
Yes, it was the connector. I cleaned it and plugged it in again and
now it is a steady 3.31 - 3.33V.
Sometimes it is the little things. I experiment so much with different
compontents that I tend to blame it on one of them.
Thanks a lot for your advice. It is very much appreciated.
Stefan
G
Guest
Guest
It sounds like your power supply is failing.
DaveW
"Stefan vom Bruch" <stefan@vombruch.com> wrote in message
news:407a2941$0$27643$61ce578d@news.syd.swiftdsl.com.au...
> Hi!
> My curent setup:
> A7V600 mainboard
> CPU: XP2700+
> TIA,
> Stefan
