A8 7600 and gtx 560 ti what will it run?
Andrej_5
Commendable
Jul 15, 2016
43
Hello!
Im upgrading from dual e7500 9800gt to a8 7600 gtx 560 ti.
I want to know what games will i be able to play?(CS:GO,Rocket league,Overwatch,assasins creed 4 black flag)
Thanks!
Your also going to need to get new ram and a new motherboard to support your processor. Also what is the model of your power supply?
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor ($64.88 @ OutletPC)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard ($43.88 @ OutletPC)
Memory: Team Elite Plus 8GB (2 x 4GB) DDR3-1600 Memory ($28.99 @ Newegg)
Video Card: MSI GeForce GTX 750 Ti 2GB Video Card ($79.99 @ Newegg)
Total: $217.74
Generated by PCPartPicker 2016-07-21 13:59 EDT-0400
This processor is cheaper and faster...
An A8 7600 will be a very decent upgrade from an E7500, when paired with a 560 ti, you should be able to play all the game you listed at very decent configurations. However, could you list your current specs and your budget so that i might suggest a better cpu+gpu for the same price?
Well i dont really have a budget,im a 14yr old trying to upgrade old pc for as little money ass possible.
CPU: E7500
GPU: Geforce 9800gt
PSU: 500W
RAM: 3GB
Thanks for your help!
Total: $217.74
This processor is cheaper and faster than the A8 7600, and its motherboard has an a lot better audibility for the future unlike the AMD.
No its not, it a lot better, it can be overclocked on the stock cooler with this motherboard and will provide a lot more single core performance, The A8 7600 may have 4 cores but its performance per core will be a lot better which is more needed for gaming. And in the future when needed you can upgrade to a 4th gen i5, but the A8 7600 doesn't have a great upgrade path.
What country do you live in Europe? I'll just make a pc part picker build from there. There a very high possibility that the particular motherboard and ram may cost alot more than similar models, so it would be better to make a new build for price and availability.
Performance per core is more important, and in the next 2 years maybe all you would have to do is replace your processor instead of your motherboard as well to an i5 when you need more performance. How much is the A8 7600+ram+mobo costing you? Also there is a significant difference between the GTX 750 and 750 ti
