Hello, I own a A8N SLI mobo, and some time back the fan was making loads of noise so I replaced with a heatsink. However I just bought myself a 8800GTS 640MB videocard, and the card wont fit because of the high heatsink!
It wont be until january next year when i`ll upgrade my system with a new mobo and all, so I need some solution until then. What sort of cooling solution can you recommend instead of my tall heat sink? I was looking at:
Cooler Master Little CHipset cooler
http://www.coolermaster.com/support/product.php?act=detail&tbcate=&a mp;id=107
However I`m confused wether that is for the mobo chipset or a video card, and then again I have no idea wether it would fit on my A8n sli chipset. Anyone knows if that would work or maybe does anyone have any other advice?
I`m pretty desperate....I dont want to leave my new graphics card gathering dust until I can get myself a new mobo/cpu/memory
Thanks for ANY help!
Mark
Mark
