A8V Deluxe problem with 3rd IDE Controller
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
After much umming and arring, yesterday I purchased an Asus A8V Deluxe motherboard, put an AMD 64 3200+ chip
on it, and replaced my old Asus P4P800 Deluxe/P4 2.8 with it.
All runs well except for the Onboard Promise Controller. In RAID mode it seems to be fine, but in IDE mode
(which sets it up as a 3rd IDE controller), Device Manager reports that the device cannot start. This occurs
both with and without drives attached.
Operating system is Windoze XP, a fresh install. Drivers are the latest ones from Asus, I flashed the
motherboard BIOS to version 1011.007 (the latest one) to see if that would fix it but still no go.
Does anyone have any ideas on how to fix this? I feel it is a driver issue rather than a hardware fault.
Thanks.
In article <cele71paq3u4nv5of7mkv7pd0k16r8s9mi@4ax.com>, Old ah heck
> motherboard, put an AMD 64 3200+ chip on it, and replaced my old Asus
> it seems to be fine, but in IDE mode (which sets it up as a 3rd IDE
> This occurs both with and without drives attached.
> latest ones from Asus, I flashed the motherboard BIOS to version
> Thanks.
There is a RAID driver for the device and an "ATA" driver.
Perhaps if you uninstall one of them and install the other,
your luck will change ?
Paul
>> Thanks.
That helped, thanks.
I wish the manual had stated that one should select SATA or IDE before installing an operating system.
