hi everyone, I am needing to know, I am currently using this motherboard https://www.asrock.com/mb/AMD/Fatal1ty%20AB350%20Gaming%20K4/index.asp paired with a ryzen 5 1600 cpu. I just bought a ryzen 5 2600 cpu cause it was dirt cheap. now my motherboard bios is version 4.90 which should work with the 2600. should I update to the latest bios or keep it where its at? ive always been scared to update the bios. or should I even upgrade to the 2600 from the 1600? I figured I can get a little faster clock speeds on both the ram and cpu. also my 1600 right now is overclocked to 4ghz 1.38 volts stable but the ram is at 2800 MHz that's max, and the ram is rated at 3000 mhz. but im using a 4x8 config. here is the ram im using http://www.xpg.com/en/feature/482
