Hi,
I have the Abit Aw9D-MAX mobo and I made the mistake of buying kingston HyperX 900 Mhz RAM to go in it. Which wont work at stock speeds with 2x 1GB loaded, it will with one. I thought one module was bad so I took my system back to the store and they are giving me the run around that the HyperX is not compatable with the AW9D-Max mobo.
The place I bought the RAM from only has Kingston ValueRam 800 Mhz available. My intention was to OC to around 3.4 - 3.6 Ghz with E6600.
Will Kingston ValueRam be good enough ? Or should I just say screw it, and go elsewhere for some Corsair Twinx.
