Abnormally high CPU temps?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
So I recently got a 212 EVO for my rig, which you can see here http://pcpartpicker.com/p/MQNHzy
However, my cpu temps are still weirdly high when idling. They go around 35 to 40C, and I don't even have it overclocked. I made sure to remove all the thermal paste using lint free coffee filters and put a small dab in the middle as I've read to do. The motherboard temps are about 30C if that matters. Are these temps normal?
Those temps are normal. Fan curves aren't aggressive at idle temps since they don't impact anything so the main goal is to keep the noise level down. If you load it up you will notice the fan speed will increase significantly over its idle speed.
