[SOLVED] about air cooling for intel i7 12700 non k
Jan 19, 2022
6
hello i have question i planning to buy intel i7 12700 non k but i don't know which good air cooling for the cpu, so does any of you guys can give me recommendation for me (excepet noctua NH-D15 can't buy because i'm afraid doens't fit with micro atx motheboard ) and sorry for my english if bad and sorry i should post on cpu forum not on graphics card my bad
Here is a link from Noctua as to which coolers are compatible with your motherboard:
https://ncc.noctua.at/motherboards/model/Gigabyte-B660M-AORUS-PRO-5496
There is no issue with pcie slot location for your motherboard.
Here is the suitability chart for the 12700 processor:
https://ncc.noctua.at/cpus/model/Intel-Core-i7-12700-1592
The NH-D15s is a high compatibility version of the NH-D15.
It will clear 64mm tall ram vs. 32mm for the NH-D15.
If your graphics card has an unusually large backplate, the NH-D15s is offset to clear it.
First things first - just because you have an mATX mobo doesn't mean you can't fit a 140mm air cooler.
What case do you have?
What is your full motherboard model #
Does your graphics card have a backplate or can you see the the PCB from the processor side? (most GPUs these days have a backplate)
Where are you shopping?
What is your budget in local currency?
Reactions: Phaaze88
case : LIAN LI LANCOOL II MESH C PERFROMANCE
motheboard: planning to buy B660M auros pro motheboard
Gpu: yes my gpu does have backplate
computer store
budget in local currency : IDR
