T Tre4st0r Reputable Aug 15, 2014 55 0 4,630 Aug 15, 2014 #1 Hi, i have a question: What is better? To buy 5 1200rpm case fans Or To buy 2 2000rpm case fans (A bit more expensive)
Solution prit87 Aug 16, 2014 get at least 3 fans 1 is already there in the front and 3 more 1 top 1 rear 1 front.....
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,817 1,871 159,590 Aug 15, 2014 #2 What case and what size fans? Upvote 0 Downvote
prit87 Splendid Jun 16, 2014 6,457 0 22,960 Aug 15, 2014 #4 also check the cfm of the fans.... Upvote 0 Downvote
T Tre4st0r Reputable Aug 15, 2014 55 0 4,630 Aug 16, 2014 #5 Case: Carbide series spec-01, 120mm fans Upvote 0 Downvote
prit87 Splendid Jun 16, 2014 6,457 0 22,960 Aug 16, 2014 Solution #6 get at least 3 fans 1 is already there in the front and 3 more 1 top 1 rear 1 front..... Upvote 0 Downvote Solution
T Tre4st0r Reputable Aug 15, 2014 55 0 4,630 Aug 16, 2014 #7 It will be enough 1 or 2 fans, one in back and one on top i think Upvote 0 Downvote
prit87 Splendid Jun 16, 2014 6,457 0 22,960 Aug 16, 2014 #8 yes you can do that i have mentioned 3 fans because 2 exhaust and 2 intake will balance the air flow... Upvote 0 Downvote
