About I5-7200U GPU, Need Help fast
VXsz
40
So
I was wondring about a laptop (2in1)And it says on the specs page it has Intel GMA hd GPU With it,
But on intel site it says, I5 have 620 HD
So which one does the Laptop have Because i want the 620 gpu (Because GMA is So slow)
Here is the link for the product:
http://www.jarir.com/yoga-520-14ikb-2-in-1-laptops-490213.html
i preorder it and i may cancel the order if it was GMA
So please if you have answer tell me
And thank you for your time.
It's a Kaby Lake CPU and it has the Intel 620 HD. It's just the shop who written the wrong iGPU.
With that said, the 620 HD is also slow and is not for gaming. You should get a laptop with a dGPU to do that.
VXsz
40
Thanks for answernig That helped me a lot,
But im not planning to play big games i might sometimes play medium one, cause im not (most of them) into these days games because most of them are online like cod ow lol and soo
But some games i might play are like the evil within 1
But the gpu is enough for 30 fps at least
DSzymborski
Curmudgeon Pursuivant
That's a mistake. The last of the GMA series of integrated GPUs (at least for consumer) came out during the Core2Duo/Core2Quad era.
Recommended specs for Evil Within 1 is a GTX 670 with min. 4 GB vRAM.
Minimum required specs are a GTX 460.
Sorry, but there is no way that an Intel 620 HD is going to play that with any decent FPS, even at lowest settings.
You will be looking at very old games, or very light games as Minecraft or Discord and such. Anything more and you won't be able to run it.
I'm just telling you so you wont get your expectations higher than what you will be able to run with an iGPU.
VXsz
40
OK
But i am an old gamer So i will be playing Games that are like from ps1 And some ps2 Games
And I MIGHT TRY games from like 2013 and so, if you wondering
And thanks for everyone for the help :D
