I need some help!
My case is NZXT 510 elite, motherboard is Rog z490-E. And I have 3140mm RGB fans+1120mm RGB fan. How to connect them all to one hue controller? Because there are only 2 led channel on the controller. Or do I need a second hue controller? So there will be 4 led channel. But in the case, I will run out of usb 2.0 on the motherboard since one is connected with NZXT kraken liquid cooler, the other one is connected with one hue controller.
Thank you!
Thank you!
